Results 1 to 12 of 12
Thread: High TA and Ph levels
    Hello,
    Just tested my pool with the TF-100 test kit and my My readings are as followed.....
    FC 3.5
    CC .05
    TA 165
    CYA 30
    PH 8.2 (or higher)
    My question is is it safe to swim with my TA being 165 and my Ph being 8.2? I have read how to lower the TA and that will in turn lower the ph? Still kind of confused how to do that...this is all new to me...I use the BBB method.
    The weather has been warm the past few days...today it is 90 out. We have not used our pool in awhile because of a cold summer. We are located about 30 min from Chicago.
    3282K gal AG INTEX
    cartridge filter
    1,000 GPH filter
    installed end of 06/2013
    22,542
    Re: High TA and Ph levels
    Add enough acid to lower it to about 7.2 and wait a few minutes and go swimming.
    Ok thank you! Can I just get muriatic acid from anywhere or is there a specific brand that works better?
    3282K gal AG INTEX
    cartridge filter
    1,000 GPH filter
    22,542
    Any brand will do, just look at the percentage and use that i the Pool calc so it'll tell you how much you need.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    You can get your pH down pretty easily. Use muriatic acid. It will also lower your TA a bit. When ph rises again add more acid. It is safe to swim with your high TA. About 11 ounces of 20 baume muriatic acid should bring your ph to about 7.5. Are you familiar with the pool calculator? You also state your ph might be higher than 8.2. I would add 14 ounces to target a pH of 7.2 in that case. That's still within good range. Based on a 3,000 gallon volume.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Thank you! Yes I'm familiar with pool calculator
    My girls wanted to go swimming and wasn't sure if it was ok to let them swim in the pool for a little before I ran my errands to get some muriatic acid. Never had to lower my TA or Ph levels so wasnt exactly sure how to do it either. Thanks for your help!!
    Alexandra
    3282K gal AG INTEX
    cartridge filter
    1,000 GPH filter
    22,542
    With the pH reading 8.2 you really don't know if it's higher than that because that's as high as the test goes. I would wait until you get it down a little to let them swim.
    I was thinking that probably would be a good idea....running to walmart now
    Thanks!
    3282K gal AG INTEX
    cartridge filter
    1,000 GPH filter
    Jul 2011
    844
    Yes, get the pH down as stated. No worry about the high TA for letting them swim though.
    Bestway SWG
    Ok so walmart doesn't sell muriatic acid they told me! Any other suggestions where to buy it from?? They had something called ph minus by HTH but were out of it
    3282K gal AG INTEX
    cartridge filter
    1,000 GPH filter
    May 2013
    Chandler Arizona
    78
    Try Home depot or lowes
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Lowe's, Home Depot or a farm store should carry it. At Lowe's don't buy the "Safer" brand/variety, it's a lower percentage and therefore more expensive for the equivalent amount of actual MA.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
