Thread: Pool heater broken
    Pool heater broken
    I have a Pentair Minimax NT. The blower was not working. A technician replaced the fan blower. It was now blowing, but the air was cold. It would not heat unless he bypassed the Air Pressure Switch. He said this is a temporary solution and he must find the electrical problem. The switch was bypassed, the heat came on for a minute and then everything went off. Now NOTHING goes on. Could the bypass have shorted out my entire heater. I am also losing water in the pool. Is this related to the heater?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Pool heater broken
    I've never seen bypassing the air switch to cause any type of total short. Didn't the tech check things out while it was running or did he run away fast after you paid them?
    When you say "NOTHING" will come on, do you mean even the display won't even turn on?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    A licensed technician worked on the heater. He is calling Pentair to ask about the electrical problem. He would not take money because it wasn't fixed. Yes, the display and the entire heater will not turn on. Any suggestions?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Did he check for power coming into the unit and then from the transformer out to the system?
    Here is the manual for the system. Page 20 has the wiring diagram. The diagram should also be posted on the inside of the door panel.
    https://www.parts4heating.com/v/vspfile ... axNTOM.pdf
    Paul
    Thank you Paul, I plan to speak with him today and will ask him about the transformer. Thanks again, Steve
