After attempting adjustment after adjustment on our (dated) Polaris 280, still can't get it not to get hung up in corners or the steps .. and trust me, we have adjusted the rear Jet to about every position possible. I also replaced the 3 wheels and the "backup" spray device - spending $100 already. But it really isn't doing a perfect job of cleaning some of the stuff that drops into our pool since it gets stuck for periods in the corners/steps. I'm in analysis paralysis mode on what to do without wasting a lot of money.
- Would you REPLACE the until with something more technically current? With what?
- Would you buy a separate Vacuum attachment & hose and just hand-vac the pool from time to time? if so, what is the Better/Best Vacuum head/device? would you go Robotic, or just something hand-held?
I'm not opposed to spend some more money to get this issue solved ... but I don't want to spend money just to find out that it's not much better & I still have to spend more for another solution.
Thanks in advance.
Thanks in advance.
