Thread: pool losing water & pump needs primed everyday?
    Lately, my pool (30,000 gallon inground vinyl) is losing water everyday - almost an inch. When the pump starts up, the pump prefilter is low/empty and it re-primes when the pump comes on. There doesn't seem to be any major visible water leaks around the pump or filter. Any ideas?
    New Brunswick Canada
    819
    Re: pool losing water & pump needs primed everyday?
    You have a air leak somewhere, I suggest you check all o rings an replace any that are looking worn. Possibly a connection has been moved, thereby causing a bend and pressure on one side of your connections?
    I'll check the o-rings this weekend but I haven't done anything regarding connections or plumbing in quite a long time.
