Results 1 to 12 of 12
Thread: Replacing one upright on round AGP
    May 2013
    Broadalbin, NY (foothills of the Adirondack Mts.)
    13
    I may just have to kill my husband. Yesterday, while mowing the lawn, he caught the rear wheel of the mower on one of the uprights of my pool and pulled it out of position. It's pretty bent up and detached at the bottom. I'm hoping we can take it off, straighten it out and re-install it. Does anyone know if this is possible? Do we need to drain any water off? There is no bulging at the location, so it seems that it's not having much of a structural impact on the pool.
    Hubby's pretty handy, so I'm not worried about his ability to fix this, we just don't really know how the upright is attached at the top, nor how it should re-attach at the bottom. We have a manual that apparently came with the pool when it was installed (it came with the house when we bought it), but it's not very easy to tell how this works.
    18' round AG pool; 7600 gallons
    Pentair Sand Dollar filter (sand)
    Pentair Dynamo 1hp pump, 80 GPM (?)
    All newly installed in 2011
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Replacing one upright on round AGP
    Never seen this discussed, but I wouldn't even think about it without draining half myself. Once metal twists, it twists in the same place again easily. I'd reinforce it with some plate.
    Nov 2011
    Moberly,MO
    1,010
    You can remove the upright and straighten it without draining, as long as no damage was done to the wall itself. On a round pool the force of the water is exerted evenly all the way around the pool. Wil-bar a manufacturer of alot of above grounds did a study of water pressure on the wall and only the fist foot into the pool is pushing outward the rest is pushing down. I would recommend replacing the upright rather than repairing.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    May 2013
    13
    Thank you for your advice. I haven't been able to find a replacement part to match. I think we'll try repairing (my husband and I are both cramftsmen) and put that in place until I can locate a matching upright. I found the number for the company today, so will contact them directly tomorrow.
    Jul 2013
    NH
    86
    Ouch. Good luck with the repair. I have no idea how to replace it, but I can't imagine it would be too difficult. I'm sure the manufacturer will give you advice as well.
    My advice....use a weedwacker on that area from now on
    Mike
    18' Sharkline Oceanic
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Use DE for your filter? DO NOT use anything but POOL GRADE DE!
    May 2013
    13
    "My advice....use a weedwacker on that area from now on "
    I TOLD my hubby his zero turn doesn't replace the line trimmer! He seems to make a game out of seeing just how close he can get. Trying not to get TOO mad about it, since I took out half of one of his blueberry bushes a few weeks ago ...of course, THAT will grow back all on its own! We're planning on putting up a deck around half the pool next year, and I think I'll do some planting around the rest. I have a feeling I know where the deck is going to go! (right over this area!)
    I'm hoping I'll be able to post some "after" pictures soon!
    Thanks for the words of encouragement and advice!
    Casey's Avatar
    SW PA
    10,463
    If this were my pool, I would actually go a little further and dig out around the bottom to see if he pulled the tracking apart with the impact of the mower. He had to of sheared off the post as they are held in by screws mainly unless it's a resin track. What you should see is a bottom metal plate with 3 tabs that the post screws into and the wall itself sits in the track. If the wall is still in the track and track is still in the plate and the plate isn't busted up or twisted from impact, the fix should be easy.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I am going to guess this is pretty simple if you can get the base loose of the track. IMHO, the risers main job is to hold the top rail in place. I really don't feel the risers are "structural" I replaced my liner last summer and I had all of the top rails off and the pool full and had no issues. The risers barely touch the walls.
    -- Guy --
    30,432
    Wil-bart needs some new engineers, then. That's just bogus.
    Fluids exert force equally in all directions. Granted there is more force at the bottom of a pool, but the top 1" of that pool water is exerting force on the sides as well as vertically.
    Apr 2010
    East Texas
    9,659
    duraleigh to the rescue!
    Jul 2010
    North Alabama
    8
    These pictures may help you see how the upright fastens to the top and bottom plates.
    24 X 52 Vogue Simbio Eclipse, 1 HP Hayward Power-Flo LX pump, Cooper Ranger sand filter
    Taylor K-1005 plus FAS/DPD test kit
    May 2013
    13
    Awesome! Thankyou so much! We haven't attempted anything yet, as we were preparing for a barbecue today. Had about 25 people over, so there was a lot of cooking to do! Probably soon now, though.
