I have a pretty standard 18 x 36 pool with 1.25 HP pump on 2" line. Polaris 3/4 HP motor. Standard size sand filter ?
Pumps are below water level by ~ 4'.
The water feature will have 3 outlets and will be on top of pool deck and will prob use a 3/4HP dedicated motor at the below water level location. Supply water will need to be pumped up hill ~ 5' + ~ 40' run.
? Where can I tap in for supply water or do I need a ($$$) dedicated new supply. If I tap into the skimmer or the main drain return at the pump area can I run my feature (additional) pump simultaneously with the main filter and polaris pumps? Or is this just not possible?
THX
THX
