Results 1 to 10 of 10
Thread: price to run nat gas heater
    my nat gas cost me $5.134 per mcf to break that down into thermal units divide by 10.23 that gives me a price of $.50 a therm. so to heat my pool 13,500 gallons 10 degrees with 3.5mph wind and a 250k btu heater at 80% efficiancy should run me aprox. $6.25 is this right
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: price to run nat gas heater
    wildwilly1:
    Here's a cost calculator spreadsheet you may want to check out: Natural Gas Heating Time & Cost Calculator Spreadsheet.
    i cant get to the spreadsheet for some reason . but idid find one online and that's where I got my calculations at do they seem right
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I got $7.04 when I entered your pool size and cost parameters in my spreadsheet. I used the net BTU's of 200,000 figured by taking the faceplate BTU's of 250,000 * 0.8. So, I think our figures are certainly in the ballpark.
    Not sure where you are located, but air temperature, sunlight, wind (as you pointed out), ground temperature, length of plumbing run, and whether your pool is covered are some of the more significant factors that impact the length of time and heating fuel it will take to raise the temperature of the pool water to a target temperature.
    sounds good just wanted to know if i was in the ballpark of price.i am in ky this summer here has been very cool and rainy. so much for global warming
    Aug 2009
    SW Wisconsin
    518
    well...I haven't used the spreadsheet yet..but I can give you a realworld comparison, albeit on a much larger pool....We ran our 200,000 btu heater the entire month of June, as it was unseasonably cool...usually around 76-78F most days. Our pool holds 25,600 gallons (33 ft diam x 52 deep). Cost for NG for the month was $300 to maintain pool temp of 84F , put that on top of our $100 gas cost for household use, and it was a good chunk of change.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    were u running it 24/7 the whole mth
    Aug 2009
    SW Wisconsin
    518
    not 7 days a week, but probably 5, and yes it was on constantly to maintain a given temp.
    Quote Originally Posted by flyweed
    Any idea what your cost per therm averages?
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Aug 2009
    SW Wisconsin
    518
    No idea..I can probably find out.
