Thread: Testing SWG Salt cell
    May 2013
    Chandler Arizona
    78
    How can I test a salt cell to verify its working properly. Looking to help a friend test their cell its a normal SWG. They have the right amont of salt for thier pool/swg manual. They run the pool filter/swg at 8 hrs a day. CYA is up at 70. FC showing 0 to .5. I currently have them adding liquid chlorine until we figure out the SWG.
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    22,539
    Re: Testing SWG Salt cell
    What brand and size cell is it?
    What test kit do you or they have?
    You can usually crack a union on the downstream side of the cell and test the FC coming out of it and compare it to the pool water and if it's a few ppm higher that means the cell is working. Make sure that the unit is generating when running that test.
    May 2013
    Chandler Arizona
    78
    I dont know the brand and cell size yet. I only have the salt test strips from TFT testkts.net, aqua check. Ill try to test downstream of cell. Thanks Bama Rambler
    22,539
    I see from your sig that you have the TF-100. Usee that to test the FC right out of the cell and in the pool. That should tell you if it's working.
