Thread: Bead split in low hung vinyl liner - In ground pool
    I'm hoping I can patch this.
    Had a small section of liner come out in shallow end of pool. While trying to get it back in I've split the "rubber bead section" about 2" horizontal split. Not sure this is rubber... thicker than the vinyl liner.
    Has anyone seen this before? Ever had to repair this?
    Looking for advice.
    Thanks!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Bead split in low hung vinyl liner - In ground pool
    When was the liner installed? This may be a warranty issue!
    Welcome to the forum!! Sorry I missed this before
    Please bear with us, it's busy, the forum got a little 'make-over' and some posts were apparently missed
    Luv& Luk
    -Ted
