Thread: Hayward RS 2000 pump
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Just a quick question , i replaced a leaking pump seal and when i put the pump back togther , the difuser did not snap back on the seal plate like they show on the youtube video .
    I just kinda crammed it all in and it works and no leaks , is it a problem that the difuser did not snap onto the seal plate ??
    Thanks...
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Hayward RS 2000 pump
    If the pump is pumping water ok then it appears the pump volute is holding the diffuser in place you will be ok
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Cool !! Its working ok ..
    Sean Hannon
