Page 1 of 16 123411 ... LastLast
Results 1 to 20 of 308
Thread: New pool/spa build in North Texas Updated: PICS
    Hello Everyone.
    I'm a new member to the forum and have gained a wealth of information over the past 3 months and have decided to give back by documenting my build from start to finish.
    After a 3 month exhaustive process, we have settled on Southernwind Pools out of Mckinney, TX. We had also interviewed Hauk, Robertson, Riverbend Sandler, Pool Environments, and Cody before deciding to go with Southernwind.
    One thing I found shocking throughout the entire process is that each builder seemed to have different opinions on construction standards, equipment etc. I had to research almost everything myself to ensure I was making an informed decision on every aspect of the build. This involved sifting through a plethora of BS from most of the builders! Cody was by far the worst and came in at a price that was astronomically higher than all of the builders, despite the fact that Southernwind takes them to school on construction quality. I also found the Cody sales rep to be extremely arrogant and out of touch. She told me that with her POS ozoneator, I could go most of the year without adding chlorine to the pool .
    I finally decided on Southernwind for a number of reasons:
    * They were straight shooters from the beginning. Spec'd my pool exactly how I asked them too. No BS, no bait and switch. I wanted the best equipment and a high end pool and that is exactly what they delivered.
    * When I went to make upgrades to the pool/equipment, they didnt try to overcharge me like some of the other builders - one builder wanted 2200$ to upgrade from an Aqualink pda 8 to a 12. What a joke.
    * Warranty - lifetime warranty on stonework, plumbing, stonescapes interior, and pool structure. 3 year warranty on Pentair equipment
    * Construction - 1/2 inch rebar, wet-mix shotcrete construction, 10-12 inch thick minimum. This is a significantly stronger structure than ANY builder in North Texas.
    * Only builder to recommend and warranty a salt water pool
    Below are the specs for my build - please feel free to provide comments:
    *133' Perimeter
    *43'x19' / 3 1/2' x 8' Deep
    *24" Raised Spa/9'x7' SPA
    *Glass tile
    *Pent Quad DE 100 filter
    * A&A MAX in floor cleaning system
    * (2) LED Pool Lights (1) LED Spa Light (intellibrite 5g)
    *Intelliflo pump
    *3hp Booster Pump
    *Air Blower
    *(6) Jets
    *400k BTU Heater
    *Easy Touch 8 Wireless Controller
    *Screenlogic 2
    *Rainbow 320 Chlorinator (backup)
    *Intellichlor IC60
    *(1) Tan Ledge (1) Swim Out
    *~950 sqft Stamped Concrete with Steps
    *Gas supply and hook up to heater
    *12" and 6" raised beam with (4) 18" Stone Scuppers.
    *Stonescapes Mini Pebble
    *18" and 24" single sided retaining walls. Stepped with grade
    * Oklahoma Flagstone for coping, retaining walls, and raised beam
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Re: New pool/spa build in Prosper, TX
    Welcome & congratulations, that's going to be a big pool! Do you have any sketches?
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    attached are some renderings of the pool
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Very nice! I really like the negative edge on the spa and the way it seamlessly integrates into the top level of decking. It's going to look fantastic when it's done.
    If you plan on using the spa a lot, have you considered making it a little bigger considering you have a fairly large pool? It will give you a little more leg room in there. Obviously it depends on how frequently you're intending to use it and how many people and if it's only going to be 1 or 2 people normally it may not be worth it (considering everything has a cost associated with it!!)
    Quote Originally Posted by cbink
    I was actually thinking the same. It wouldnt impact the design too much to pull it out 12 inches on each side. I will definitely follow up with the pb to get a cost estimate. We'll be using the spa heavily.
    Jul 2013
    Prosper, TX
    133
    Re: New pool/spa build in North Texas
    This is getting to be a Prosper-heavy forum.
    18,600 gal, IG, Jandy 60 sq ft DE filter, 2HP VS pump
    Stonescapes Tahoe Blue mini pebble
    Getting ready to start the dig sometime next week. One thing I currently do not have spec'd on the pool is auto fill. The builder is trying to talk me out of it saying it would be impossible to tell if the pool was leaking and so they recommend just installing a line from the hose outlet under the decking.
    So far I've felt they have been honest in relation to other pool builders I've worked with. Yet, everyone I know with auto fill loves it.
    Does the pool builders argument carry any weight?
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Quote Originally Posted by jamcha02
    Pool rendering looks awesome...
    Here's my take on the Auto fill. Mine was installed with a manual anti-siphon valve located at the equipment pad. If I want to check for a leak, I just turn the valve off. It as easy as turning off a valve if you want to manually fill your water. I would just get it installed, and then check for a leaks a couple times a season. The rest of the time, just forget it.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Re: New pool/spa build in North Texas Updated: PICS
    Got a call from the pool builder at 7am this morning. "The permit was approved this morning and Im sending over the calvary."
    more photos
    dropping the yard down 2 feet for the retaining walls.
    Aug 2010
    Dallas, TX
    4,052
    Have you picked your tile yet? I was just talking to a PB and he suggested going to Noble Tile in Dallas (Shady Ln and Walnut Hill) to look at samples. I was just on their website at http://nobletile.com and looking around, but it appears the website went down. We are also looking at glass tile.
    My auto fill is disconnected. I've had leak issues over the years, and the water bills get pretty steep when the fill keeps up. Getting a water bill for 125,000 gallons isn't a pleasant experience (some of this was irrigation I must admit).
    I may call your PB about my remodeling. I like your experience comments so far.
    Quote Originally Posted by RobbieH
    We have picked the tile. Its a glass tile from National Pool Tile group. You can look it up online at http://www.nptpool.com. Its the Canyon Gems series - Blue Cobalt. This tile will be used all the way around the pool at the waterline and for the negative edge on the spa.
    As far as the builder, I cannot say enough good things about them. http://www.southernwindpools.com. They've been in business for over 30 years and the owner, John Versfelt, is onsite managing the entire project. Communication has been spot on and I am confident that he'll give me everything I've signed up for.
    Day 1 of excavation is complete. The excavator dug down 9 feet just to ensure we wouldnt hit rock (and we didnt). They will be back tomorrow AM to finish the dig.
    We decided to add an A&A MAX in floor cleaner to the build. Lifetime warranty on all parts from A&A and the PB warrants all the plumbing under the pool and to the equipment pad for life.
    So far everything is going very smooth.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Looking good! Keep the pics coming!
    Day 2...the dig continues
    Almost done
    Here is a copy of the in floor cleaning system engineering diagram in case anyone was interested
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Wow that is a lot of cleaner heads
    First, a disclaimer...I do not have a in-floor system and I tend to be a minimalist so I probably would not put one in if I had a igp, but...I would attempt to reduce the number heads since the experiences I have read on this board tend to suggest problems and I assume the problems would be magnified with that many.
  20. Back To Top    #20
    Quote Originally Posted by linen
    @Linen, thanks for the feedback. This drawing is directly from A&A's engineering department, so it would not be advisable to make changes.
    Many of the issues relating to dead spots in the pool are because the pool builder reduces the number of heads and doesnt follow the plan provided by the manufacturer. I think if these systems are installed correctly they work great. My builder has installed over 200.
    Also, all of the heads/other parts are warrantied by A&A for life. The plumbing runs are warrantied by the PB for life.
