Thread: How was tf-100 developed?
    Jul 2012
    Herndon, VA
    419
    Has this question been asked and answered? How was the tf-100 developed? Solely by duraleigh?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: How was tf-100 developed?
    IIRC, the TF is an answer to the availability of the tests required for the average residential pool owner. It uses the same Taylor based reagents as the Taylor kit (and the Leslie branded versions). He uses the Taylor reagents and packages them into the sizes needed by the residential owner, in quantities to last a season or two. I believe it was developed by Duraleigh and Sean.
    I think there is a thread here with a more complete answer.
    -- Guy --
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I don't know the exact story, but the effect has been to create an improved version of the Taylor K2006 test kit (as mentioned above both use Taylor brand reagents), where you get more of the reagents that you use the most, instead of a kit filled with matching size bottles of reagents with no regard to how much of each you may use in a typical testing situation. The clearest example of this is the K-2006 matching size (.75 OZ) bottles of R-0871 (used 1 drop per .5 ppm FC or CC in the 10 ml sample size FAS-DPD chlorine test, and R-0003 reagent that requires 5 drops for the CC part of each test. This means unless your FC is less than 2 or maybe 2.5 ppm you will always run out of R-0871 first in the K-2006 kit. By comparison the TF-100 comes with a 2 OZ bottle of R-0871. Sure all this comes at a slightly higher initial price than the K-2006, but proves more economical in the long run, the TF-100 also does not contain the acid and base demand tests that are included in the K-2006 as we generally feel are not needed and can be calculated close enough by pool calculator using the results from your TA test. These tests may be of some value in a dose and forget pool service call, but even without the use of pool calculator they have limited benefit on a frequently tested residential pool.
    Ike
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by GuinnessPhish
    There is history involving different people and pool forums from the past. One of the older forum veterans here would be better suited to give you the answers of a historical nature than I can. I remember reading about the evolution of it, but don't remember enough to explain it all.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    You can read more about this topic in the thread Behind the scenes at TF Test Kits? You can also see the PS-234 test kit Ben Powell created at PoolSolutions (it is no longer available) in this link.
