Thread: [[FC Shock Level Question]]
    Aug 2013
    Phoenix, AZ
    25
    Hello...
    So I just drained over 2/3 of our pool and going to SLAM it. I have ran the tests for my PH and the levels are at 7.5... I am curious how much chlorine/bleach I should use? After running the test it looks like I have .5ppm, and I am confused at what level I should SLAM it to as the recommended levels are 3-7 (pool-school/recommended_levels) maintenance, but I am seeing shock levels on here at 30ppm.
    I have 10% liquid chlorine, and I am am just curious if I should raise them to 30ppm or the 3-7ppm with pretty much clear fresh water with no signs of algae?
    If 30, I am showing via the http://www.poolcalculator.com/ to add 334 oz or 2.2 Gallons or if 7ppm I should add 74 oz or 2 quarts 1 cup 2 oz.
    Thanks!
    10000 Gallon Inground Plaster Pool with attached Spa, 2 Horse Pump, Hayward s244S Sand Filter, Hayward H250FD Heater, Quick Skim, Water Feature (waterfall from Spa to Pool), In-ground Pop-up Cleaning System (4 in spa, 13 in pool)
    38,301
    Re: [[FC Shock Level Question]]
    Why are you going to SLAM if you have no reason? You would use the 30ppm for the shock level. You can do the OCLT to see if something is in the water requiring the SLAM process.
    Aug 2013
    Phoenix, AZ
    25
    Hey jblizzle... I was told by @linen to SLAM my pool after I drained it (pool-constantly-cloudy-t68212.html)
    38,301
    Well, this is why you should keep your questions together.
    Then SLAM it and maintain 30ppm.
    Aug 2013
    Phoenix, AZ
    25
    great advice... thx!
