Results 1 to 7 of 7
Thread: Bacquacil CRX, low pH
    Aug 2013
    NEOhio
    6
    I have had my pool for 1 year, installed 7-12. Bacquacil CRX; lately it has been white clouds, PH is below the recommended level,7.2,can I use borax to raise the PH or is this a big no-no with this CRX system? I have used bacquacil PH increaser and not much luck. The TA is very high over 90, I wish I had found this site last year. Probably going to do the big switch over in 2-3 weeks! thank you in advance!
    24 ft rd. x 54" 14200 gal ag; Heyward 1.0 hp pump and sand filter; Rheem htr
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bacquacil CRX, low pH
    Welcome to TFP!
    I believe you mean the Baquacil® CDX™ System, not CRX. They use CDX to help stabilize the oxidize (hydrogen peroxide) in the pool.
    The main problem with the CDX is that you may find it more difficult to convert to chlorine even if you let the Baquacil level get low. Using chlorine to convert oxidizes the Baquacil into lovely colors, but the CDX is more difficult and may result in you measuring Combined Chlorine (CC) for quite some time. The good news is that this CC isn't the "bad" kind (it's chlorine combined with the chemical in CDX) but it makes it difficult to know if you have "real" CC.
    Nevertheless, there are people who have had Baquacil CDX who have converted.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Compared to the cost of converting over from Baq to CL, not to mention the CC headache, would it be cheaper for you to do a drain and fill?
    Here in Oregon it'd probably only cost me about $20, if that! Our rates being one of the highest in the state.
    How high is your water table, or deep, as the case may be?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Aug 2013
    NEOhio
    6
    Quote Originally Posted by y_not
    I have city water and it cost about $75 to fill last year but then I also had sewer charge of $68, $143 total. I see I would need to change out my sand in the filter so I am looking at $170 since we had rate increase in the past year.
    My original question is if I can use Borax to raise PH with CDX?
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    Call the water company, as often they'll wave the sewage charge. As for the PH.....you should be able to raise it with Borax.
    Aug 2013
    NEOhio
    6
    Thanks for the reply. Not in this county will they wave any fee, I argued this last year when I filled it.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by pbpool
    Yes you can. Borax is not incompatible with Baquacil or CDX.
