Thread: Help identifying check valve
    Feb 2012
    Cypress, TX
    131
    One of my check valves has a crack/leak in the cover. I am having a hard time finding the correct one to see if a replacement cover is available. Does anyone have one like this and do you know what the brand/model is? Thanks.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    38,475
    Re: Help identifying check valve
    Interesting. Never seen one like that before and I had not luck searching either ... sorry.
    22,553
    Here's one of them. It's an American Granby CR.
    Feb 2012
    Cypress, TX
    131
    That's it. Thanks. I managed to find one late last night. I ordered the lid/cover for about $20
    Tecumseh, MI
    53
    Can someone tell this novice what a "check valve" actually is / actually does? In case I ever need to know? Thanks.
    ~12,500 sqft above ground, 95 sq ft Sta-Rite Posi-Clear Cartridge filter, installed by previous owner in 2010?, Proud TF100 user!
    22,553
    It only allows the water to flow in one direction. More to the point, it stops water from flowing backward from it's normal flow direction.
    It's common pool/spa use is to keep the spa from draining back into the pool when the pump is off. There are other uses, but that's probably the most common.
