Results 1 to 10 of 10
Thread: How often to add water?
    Brand new in ground pool, maybe I'm paranoid but how often should I be needing to add water? Or do I have a leak?
    Johnny
    IG
    Brand New
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: How often to add water?
    How much you add and how often will depend on where you are at and how hot it is.
    How often are you adding water?
    How much are you adding? In inches is what we normally discuss.
    I am in California and it's been mild this month (90-100F) and between the kids and sun, I add about an inch a week.
    -- Guy --
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    In Texas we just leave the hose hangin' over the side in August..............
    One way to test for a leak is to do the bucket test. Fill a bucket to a certain point and set it out on the pool deck. Both the pool and the bucket should lose the same amount of water from evaporation.
    21.5K gal, vinyl, ?? HP Jacuzzi pump, sand filter
    I'm in Ontario Canada. It's been 70-80 at most. But lots of kids jumping. Maybe an inch or two every two weeks? What you think?
    Thanks
    IG
    Brand New
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Doesn't perk my ears up, but, it's hard to say.
    As TaterGun said, the bucket test is the simplest way to convince yourself. Personally, I like to put the bucket on the step inside the pool so that it stays at the same temperature as the rest of the pool water. Put a heavy rock in the bucket (so it's not going anywhere), and equalize the level of the water in/out of the bucket and let it sit on the step inside the pool or 4-5 days. If you can detect any difference in the level inside vs outside the bucket, then you have a leak.
    Make sure it has enough height above the water line to keep the waves and splashes out. I like to pull it out of the water when the kids are playing, just to remove the temptation of them using it as a toy.
    Good luck!
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Quote Originally Posted by Johnny LaRue
    Thanks
    The bucket test is the best way to tell for sure, but an inch or two every two weeks is not a lot, and could be from evaporation, splash out and/or backwashing.
    Support the site
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    That sounds like about half my loss but its been hot this week. Bucket test will let you know for sure.
    -- Guy --
    mmn's Avatar
    Jul 2013
    South Florida
    34
    Quote Originally Posted by woodyp
    I used to do that and found I was losing a lot of water. Couldn't find the leak so I hired some pros. They spent 4 hours and couldn't find the leak either. They put some water in the pool and then pulled the hose out. Cost me $325 and I still didn't know where the leak was.
    Guess what? Yep. Siphoning out through a leaky hose!
    Regards
    Michael
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As many others have stated, how often you add water depends on the temperature, amount of sunlight, water loss due to splash-out, and whether there are any leaks, to name the most common factors. What I would suggest is that you need a baseline to help determine what is "normal" for your pool. Beginning with your next top-off, I would keep a log of all top-offs. After a year, this will give you a baseline that will account for seasonal variations. Once you have this baseline, any sudden variances will become readily apparent.
    Yep, that's pretty much the case here too. Right now, I am topping of weekly - entirely normal for my pool in August. Once we get past mid-September, that frequency should begin to diminish.
