Results 1 to 8 of 8
Thread: Coping Grout Question
    We had our pool installed last year. We've had grout issues since it was installed and are looking to have it re-done.
    We have an expansion joint behind our grout stones filled with caulk (not sure what is underneath the caulk), coping stones with cracking and shrunken grout between each stone, and then grout beneath the coping stones where they butt up to the actual pool itself. The grout there is falling out in chunks.
    We have several estimates, but none of the masons want to do the whole thing, they want to caulk over the grout in the underneath joint and they want us to drain our pool to do the work.
    I have one bid that I feel better about. He has estimated the full job, which includes removal of all grout, regrouting between the stones, and using caulk in the underneath joint around the pool.
    There is a strange thing in his bid though. He wants to do 9-11 expansion joints between the stones by caulking between those stones instead of grouting those. The rest would be grouted. Is this normal?
    Chesterfield, MO
    In Ground vinyl liner pool
    - Lagoon Shape - 40'x30'x20'
    - Intelliflo VS Pump
    - Intellichlor Salt System
    - Triton II Sand Filter
    - Pentair MasterTemp Heater
    - EZ Touch Controller
    - Faux stone water feature with sheer descents
    - Turbo twister slide
    Feb 2008
    Denton, TX
    5,061
    Re: Coping Grout Question
    Can you post some pictures to show us what you have going on?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I forget the exact dimension, but in tile layouts you need an expansion joint every 20 feet or something. He clearly thanks expansion is causing the grout failure. Got pictures?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Here's some layout and close up photos.
    Chesterfield, MO
    Hi bfassler. Haven't seen any follow ups on this. How'd you make out?
    10k gallon fiberglass freeform pool, Paramount SwingJet system, Dolphin DX5 robot, Pentair 48" Tagelus sand filter with glass media, WhisperFlo 1 HP pump, Hayward H200FDN natural gas heater, TF-100 Test Kit, and, of course, Margaritaville Tahiti blender!
    I need some help!!
    Chesterfield, MO
    We're going to move forward with repairs, was just wondering if anyone could confirm the contractor's approach described above.
    Chesterfield, MO
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Coping looks like concrete chunks, so here is some reading on its expansion
    http://www.johnbridge.com/articles/conc ... ol-joints/
    Here is info I was talking about earlier http://www.johnbridge.com/vbulletin/sho ... php?t=1976
    My gut says either poor original job or you have expansion issues. Your repair guy seems to understand that possibility. It may be that you could go with fewer joints than he is wanting to do, but you are paying him for his expertise.
    They do make sanded caulk that can match grout with color and texture (somewhat).
    18'x43' Sport Pool
