Thread: Chlorinator off - Low Temp message
    Split by moderator from HERE. Please start your own thread. Thanks, jblizzle
    I have the same error message - chlorinator off low temp. However, my display tells me the pool temp is 81 degrees. I should mention I think we had a lightning strike last week and I have replaced my main board last week and two relays today. All seemed to be well until we replaced the relays today. Any ideas? Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Chlorinator off - Low Temp message
    What brand/model of SWG do you have?
    Some have a separate sensor for the cell which may have gone bad or the sensing circuit may have gone bad.
    Mark
