Results 1 to 8 of 8
Thread: hayward super pump wiring help
    I just opened up the box to my Hayward super pump (sp2607x10) and noticed there was no cord. I've got the pool guy coming Thursday to install the pool. I need to make sure I have power so he can connect the pump. Can I add a cord to the pump or do I need to hardwire it to the breaker?
    Thanks
    38,428
    Re: hayward super pump wiring help
    Do you not run the pump with a timer? You should hard wire it to the timer ... or I guess a breaker if you do not use a timer (which you should )
    The wiring diagram is on the the placard on the motor.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    You can do either. I would check code in your area but you can use either either a "whip" or hard wire it. Code requires a twist lock cord if you are using an outlet, IIRC
    -- Guy --
    How do I connect the cord to the pump?
    I thought i could plug the pump into a timer i use for the holiday lights. The timer would then plug into the outlet that connects to the new 15 amp circuit breaker. Will that work?
    38,428
    That is highly likely not to meet code. You need to check what is required by your local ordinances.
    You would connect the cord to the pump the same way you would hook any hard wiring to the pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also note most Super Pump models can be wired either 120V or 240V, this may mean wiring to a different screw terminal, or moving a jumper on the motor, or both. You will not find detailed instructions in the manual only a diagram on the motor, this is because the motor manufacturer tends to change the wiring connections with different updates to the motor design. I have owned a few Super Pumps over the years, and I don't think any two had the exact same connection on the motor. There are many youtube videos that show hot to wire pool pumps, perhaps one of those would be helpful for you.
    Ike
    Jul 2012
    Ohio
    19
    I am having my pool installed this week. I am by no means an electrician, neither am I offering advice. I am simply telling you what I did. My PB told me I need a 220 line run to the location of the equipment. I ran 2 pole 20amp GFCI breaker from my box to the equipment location. If I had to do it all again, I would use a regular 2 pole 30 amp breaker in my main box and then run that to a sub box that would contain the 2 pole 20amp GFCI breaker. That would give me more flexibility at the equipment pad.
    21K gallon 18'6" x 36' 6" Grecian IG Pool. Hayward Swim Clear cartridge filter and 1HP Hayward pump
    Will be installed at the end of July!!!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If you ran a couple extra wires to the pad you could have both 220 and 110 at the pad so you could add a 220 timer to run the pump and have the code required 110 convenience outlet. OR, you can run 220 a subpanel near the pool and break it out in that panel. But IIRC you would need to have a separate grounding loop there. 110 and 220 use the same number of conductors, its all in how they are connected.
    I am not an electrician.
    -- Guy --
