Thread: danathorne
    danathorne
    Hi,
    New to the site and slowly learnign my way around the pool.
    I am looking for a reputable pump rebuild service in the Chicago area. I have acumulated a number of pumps ovet the years and want to investigate if it is worth while to rebuild.
    Also, does anyone have any words of wisdom about the best pump for a salt water pool? Mine seem to develope leaks fairly quickly.
    38,521
    Re: danathorne
    Welcome to TFP!
    There are no special pumps for SWG pools, the salt level is about triple that found in a "normal" pool, but still 1/10 that found in the ocean.
    I think there are some shaft seals designed for true ocean salt water, but not sure if they work any better.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: danathorne
    danathorne:
    jblizzle has you covered on the pumps for a SWG. So I will simply extend a warm welcome to TFP!
    Feb 2008
    Denton, TX
    5,061
    Re: danathorne
    Welcome to TFP!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: danathorne
    Welcome to TFP! Come back often and enjoy the forums.
    Essential Links:
