Results 1 to 16 of 16
Thread: Lost pressure
    Lost pressure
    Hey all.. my pool generally runs 12-18PSI.. I noticed my heater shows LO (not enough flow I am guessing) and the PSI gauge on the cart filter canister is only readying about 3PSI. I did buy a riding mower recently and accidently blew a bunch of grass clippings in the pool.. cleaned out skimmers and pump filter basket as well as swapped out the four filter cartridges with some spares I ahd.. there were no clippings in the cartridge filters, but they were a bit slimy. I am at a loss. Any idea what else might be the culprit?
    The water flow into the pump seems OK I think.. see pic.
    2003 Marquis Euphoria - 400gal
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Lost pressure
    My first guess is a clogged suction line
    Re: Lost pressure
    Quote Originally Posted by Isaac-1
    Kinda what I was thinking.. is this a DIY fix?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Lost pressure
    Quote Originally Posted by jjdurrant
    The clippings might have gotten stuck in the impeller. Check the impeller inlet first to see if you can pull anything out but you might need to take the pump apart.
    Mark
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Re: Lost pressure
    The grass clippings could make it through the skimmer basket and the pump basket and also clog the pump impeller.
    Edit: typing along with you MAS
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Re: Lost pressure
    Here's another idea. The grass "may" have gotten by the pump basket and gotten wound around the impeller of the pump. Kill all power to the pump then remove the pump strainer. Reach in with your fingers and feel if there is anything around the impeller. If so, just keep pulling it out and wash it all out with a garden hose. Replace all the hardware and give it a whirl. Has worked for me several time with pine needles and for some others as well. GOOD LUCK!!!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Re: Lost pressure
    LOL...fast responses huh???
    nedchavez's Avatar
    Jun 2012
    111
    Re: Lost pressure
    Lol. Sounds like MAS, samiguy, and I have all had the same problem at one time.
    Re: Lost pressure
    Thanks guys.. I verified is wasn't a suction line as I am able to draw plenty of water from each one at a time. I am up to 5psi.. I will check the impeller and report back.
    Re: Lost pressure
    Oh yes I have!! I've got $ .05 that it's clipping on/in the impeller.......
    Re: Lost pressure
    Consider using a skimmer sock. I only clean out pump basket once a season.
    Gary R
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lost pressure
    I use skimmer socks all the time, they work great.
    Jeff
    Re: Lost pressure
    I do as well.. but the clippings were just too many!
    Re: Lost pressure
    Thanks guys.. it was indeed grass clippings in the impeller. Sprayed everything out with garden house and all is well again!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lost pressure
    Good job !!
    Jeff
    Re: Lost pressure
    Ah yes......another winner!!!!!
    (I'll take my nickel now!)LOL...
    Sami
