Thread: Fusion Soft 2 SWG Problem
    We have a Fusion Soft 2 SWG for our 17000 IGP and up until recently was working flawlessly. We had our pool refurbished with pebble sheen,
    so it was drained for about a month. Refilled and let the surface cure for a month before we added the salt.
    The system and pool are new, less that 18 months old. Last Thursday, I got an error code saying the electrolytic cell was dirty,
    so I removed it and saw that it was caked with mineral deposits. Cleaned it in a 4:1 mixture of water and muriatic acid,
    cleaned up fine. Replaced the cell and reset the chlorine production to 75%. Tested the water this morning and have
    zero residual chlorine. I currently run my filter pump from 9:00-11:30 @ 2800 RPM for the in pool vac to run then in kicks
    down to 1800 RPM from 11:30-6:00. Pool salt was added on Aug. 12th.
    Any thoughts as to why this is happening and how can I fix it?
    Thanks...
    Re: Fusion Soft 2 SWG Problem
    Your levels are out of balance, probably in more than one way. You should post a complete set of water test results so we can see what is going on.
    Levels as of this morning:
    FCl = 0
    Alk = 100
    ph = 7.7
    Cya = 40
    ***UPDATE***
    Turns out the flow at 1800 RPM was too low to activate the cell, so I increased it by 100 until the "No Flow" warning went away, stopping at 2300 RPM.
    Now the display shows "Flow and Cell On". Production at 80%. Will check the levels tomorrow.
    I think that did it.
    Mar 2015
    Modesto, CA
    5
    Did that resolve your issue?
