Thread: Green water
    Jul 2013
    Fort Wayne, IN
    2
    Green water
    Our pool water was starting to turn a little green so I tested the water and here were the results a couple of days ago:
    FC 0 - .5
    PH 7.8
    TA 240
    Copper 0
    CYA 0
    TH 100
    We added the following (per the pool calculator): 55 lbs salt, 60 ounces of stabilizer, 76 ounces of bleach and some PH minus.
    I tested the water again tonight and here are the readings:
    FC 0
    PH 7.5
    TA 80
    Copper 0
    CYA 0
    TH 200
    My husband vacuumed the pool and now it looks even more green than it did before! Any suggestions for what we should do now?????
    14,667 Gallon 26 x 52 Intex Above Ground Round Cartridge filter ~ filtering capacity of 2,500 per hour.
    Intex Krystal Clear Saltwater System (SWG)
    Purchased and installed in June 2013
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Green water
    Firstly: Welcome to TFP
    I think you may have misunderstood the pool calculator. Why did you need to add 55 lbs of salt? You have an SWG in your sig but you don't have any salt level mentioned.
    To help you we need to know: 1. Where you got those test results?, and 2. A bit more about your pool (use This as a guideline)
    After you get that information it would be a good idea to do some reading in the Pool School while you wait for a response. It will help you understand the answers we give you, and in the long run prevent future problems.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2013
    Fort Wayne, IN
    2
    Re: Green water
    Sorry for forgetting to put the salt level in the original post, it was 2930. I tested the water using test strips as the pool store was closed to take my water sample there. I added the additional pool information (at least what I could find) in my profile so I hope that helps.
    Aug 2013
    Oklahoma City, OK
    140
    Re: Green water
    Time to SLAM!
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    May 2013
    Bay City, Michigan
    283
    Re: Green water
    Is there a typo? it says you went from TA of 240 to 80
    In short, your water turned green because you didn't have enough chlorine. You didn't have enough chlorine because you had zero CYA. (CYA protects the chlorine from being consumed by the sunlight among other things) Without the protection from CYA your SWG could not make chlorine fast enough to keep it in the pool.
    First, pool store tests and test strips are not the best or most accurate method. The Taylor K-2006 or the TF-50 or TF-100 are the recommended ones with the tests you will need. For the price the TF-100 is a good deal since it has larger size reagents. Your gonna need those extra chlorine tests for a green pool. Those are recommned because they all have the FAS/DPD chlorine test. http://tftestkits.net/cart.html?m=splash
    Adding the stabilizer is exactly what you needed to do, it just doesn't show up in the test for up to a week or more. Use the Chlorine/CYA chart and treat your pool as your CYA level is what you aimed for.
    SLAM it. http://www.troublefreepool.com/pool-...king_your_pool
    Check out pool school as it is very useful and explains a lot. http://www.troublefreepool.com/pool-school/
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
