Thread: find model of Hayward heater
    Hi,
    I have a Hayward gas heater for an in ground pool and I need to figure out the model #. It was probably put in about 2002 or 2003 by the previous owner of our house. I can't find the serial or model number anywhere on it. I would expect to see one of those metal manufacturer plates on it, but there isn't. is it possibly behind the front panel oe something?
    thanks!
    20k gallon IG fiberglass sand-filtered chlorine system. 1 HP single speed AO Smith pump. Pool built in 1965, fiberglass repaired in 2007, 2013 fiberglass and deck repaired.
    Jun 2012
    western NY
    1,560
    Re: find model of Hayward heater
    Most likely behind the front panel. Should be the model #, Serial #, Etc. Should also be the wiring schematic.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    It was there!
    Thanks danpik
