Thread: Error Code 4 on Pentair Water EasyTouch Pool
    I recently cleaned my IECG blades using muriatic acid. After reinstalling the IECG the the EasyTouch control panel is showing a POOL ERROR. I ran the Diagnostic test which resulted in an Error Code 4. (Switch (buttons)) I do I correct this Error Code 4? Any assistance would be great.
    Thanks, Mary
    Re: Error Code 4 on Pentair Water EasyTouch Pool
    Error code 4 means that one or more of the buttons are stuck in the pressed position. When cleaning a Pentair SWG it is very important not to allow any water or acid to get into the electronics area. It sounds like that might have happened here. In any case, pressing each of the buttons a couple of times might clear the error, or it might clear when the unit dries out, or it may need to be replaced.
    Thanks for the info. I hope it will resolve itself. I probably got some water in it. Going to fiddle with it for a fews day. Thanks! Mary
