Thread: Can I swim after adding chlorine?
    I am sure this has been asked before but I cannot seem to find a post. Is there a waiting period after adding chlorine, liquid bleach, before swimming? I would assume that as long as I brush the pool afterwards I should be good to go but I just want to make sure.
    Coppell, TX
    11,000 gallons
    DE Filter
    In Ground/Pebbletec
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Can I swim after adding chlorine?
    Half an hour tops if poured in front of a return jet and pool circulating. Welcome!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    What he said ^^^^
    If you pour it in in front of a return and then go change, it will probably be safe to get in by the time you're ready to get in. Your splashing around will disperse it and mix it as well as anything.
