Thread: Question on Closing an Above Ground Pool
    May 2013
    Hudsonville, Michigan
    13
    I have a had pretty good success with using the TFP method this summer, so now I am thinking about how you recommend closing as far as chemicals go.
    We usually wait till early October and dump in what the pool store sells. What are the TFP recommendations?
    Not sure if I have my info in my sig, we have a 24 ft round AG with a deep end, around 16000 gallons.
    AS far as the pillow goes, here in Michigan we are told that the pillow prevents damage to the pool walls from the water freezing. It is expected that the pillows only last a year, but we have actually not lost any of ours. 1 for a round pool, 2 for an oval.
    Swimming in Grand Rapids Michigan since 2005
    Doughboy 24 ft round AG, 17 k gallons
    DE filter
    White River 1 HP JH pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Question on Closing an Above Ground Pool
    Welcome to TFP
    The only chems I plan on using to close is bleach. I plan on putting the winter cover on when the leaves begin to fall and just maintain my levels as always. Then when its time to pull the pump and filter, when temps are getting close to freezing, I'll bring my FC up to shock level for my CYA level with bleach and I should be good to go.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,904
    Never used a pillow nor has my pool been destroyed by freezing water, but it doesn't hurt to use them. As for chemicals, I lower the pH to 7.2 and raise the FC to SLAM level the night before and raise it back up if needed in the morning before I start draining. That's all I do to the water, I stopped using an algaecide a few years ago. The FC loss for a covered pool with near freezing water is so low that I still get an FC reading when I open it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
