Thread: How can i get rid of these stains? Please help.
    I recently inherited responsibility for keeping up the pool. Before I got it figured out, it was dirty and green and swampish for a while. Now that it's clean, I'm noticing that stains that existed before now seem to be intensified. They have gotten a lot worse. Is there any way I can get rid of them or fade them even just a little. I will try to attach a photo, but it may or may not work. Please someone help. I'm only a teen and I'm not really sure on all this stuff. If you need more pictures, just ask. The one I posted isn't the best but its of the bottom of the pool.
    I"m not quite sure about anything but i do know that its a 32,000 gallon pool
    Re: How can i get rid of these stains? Please help.
    How old is te pool ?
    My 10 year old liner in my previous above ground pool ended up looking like that in places, it was on the underside of the liner.
    My Hayward Aquarite Repair write-up here: https://www.facebook.com/#!/HaywardAquariteRepair
    Quote Originally Posted by p_mori7
    I'm not quite sure but I'd say atleast 30 years old, most likely a lot more.
    I've seen the following suggested:
    - Hold a trichlor tablet to one of the stains. If this lightens or removes the stain, it is organic (perhaps from leaves sitting on the bottom, for example). Maintaining the proper chlorine level and brushing the pool will lighten them over time.
    - If the trichlor does nothing, the stains may be from metal. Try holding a vitamin C tablet on a stain and see if it lightens or removes the stain. If so, it is a metal stain. If there is some other change instead, describe it and hopefully an expert can chime in.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
