Results 1 to 20 of 20
Thread: Crazy readings
    Jun 2013
    Northern NJ
    123
    Crazy readings
    Ok with the Taylor test kit my reading is
    FC 14.5
    Cya 100
    Ph 7.2
    Alk 110
    I imagine my FC is high due to my cya level. Is it harmful with such a high chlorine level? I know I have to drain my pool to get the cya down In the meantime what can I do? Can't drain the water yet
    Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Crazy readings
    What does the water look like?
    That FC level is not that high since you have high cya. In fact, your cya is likely higher than 100 since the test is not too accurate that high. If it is 100 ppm cya then your "normal" chlorine range is 8-13 ppm (per poolcalculator.com). See: http://www.troublefreepool.com/pool-...ater_chemistry and http://www.troublefreepool.com/pool-...ya_chart_shock
    May 2013
    Bay City, Michigan
    283
    Re: Crazy readings
    With CYA at 100 your FC minimum is 7, target of 12 and it is safe to swim up to shock level (39) Keep your chlorine above 7 at all times until you can drain and refill.
    Your chlorine is high because of the amount of chlorine added. (But really its not high at all) (It kind of sounds like your saying your high CYA created your high chlorine so just clarifying that) High chlorine is NEEDED because of your high CYA. Are you sure its not higher cause I think it maxes at 100)
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Crazy readings
    Unless you have already done so, try re-doing the CYA test using a 50/50 mix of pool and tap water, then double the result ... that will allow you to maybe get a better estimate, especially if it is > 100ppm.
    You're done SLAMing when:
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Crazy readings
    I think it should also be noted that pH readings are not accurate when FC is above 10. It may be lower than 7.2 and need adjusted.
    I also second Butterfly's suggestion, mix half tap water with half pool water and use that to do a CYA test. Get a reading and double the results, that will give you a closer reading of your actual CYA level and allow you to maintain your pool until a drain is possible. You will absolutely want to maintain proper FC levels, an algae bloom would be very difficult right now.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    That's amazing because I haven't added anything. But baking soda in weeks
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    My water is crystal clear
    30,419
    Re: Crazy readings
    So you have a saltwater pool, correct?
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    No saltwater. Chlorine. Was using trichlor. Used the last one over a week ago. My Clorox is ready when needed
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Crazy readings
    Back in July you shared your first readings with a TF-100, now you have a taylor kit? I don't understand, did you buy a different kit? You said back then your CYA was 180, unless you have changed water then that is still true, and if you have been using trichlor this whole time then your CYA is even higher than that.
    May 2013
    Bay City, Michigan
    283
    Re: Crazy readings
    Quote Originally Posted by Thesil
    Whats amazing? that your chlorine is where it's at or that your PH might be lower than 7.2?
    If you haven't added liquid chlorine/bleach, that does seem amazing for your FC to get to 14 with tabs alone, though, I don't know what your putting them in and how many at a time.
    The use of Tabs lowers your ph.
    30,419
    Re: Crazy readings
    Well, this thread is getting pretty confusing. I can't follow it anymore.
    Back to OP's original question....With a CYA of 100, your FC needs to remain between 7-12 ppm NEVER lower than 7 ppm.
    OP, you need to read and re-read Pool School and consult the FC/CYA chart.
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    Quote Originally Posted by Donldson
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    No I misspoke. It's a TF - 100 test kit. Don't know why I said Taylor
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Crazy readings
    Well, TF100 uses Taylor chemicals
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    Guess that's why I said it. Must have seen it on one if the chemicals.
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Crazy readings
    Very true Butterfly, I just wanted to clarify. Thesil, if you haven't done a water change and continued using trichlor up until a week ago your CYA is somewhere around 200. In that case 14.5 is below your minimum of 15. you must keep your FC level between 15-23 at all times to avoid any problems.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Crazy readings
    And that time is now. If you still have any pucks you must stop using them. I remember your other posts with high CYA, and high water cost in Houston right? You will have a battle with CYA so high and it really needs to come down. Can you not drain any water...a little at a time to avoid the over 10K and 20K gallon up-charge?
    Also, can you please put your pool info in your signature line?
    Essential Links:
    Jun 2013
    Northern NJ
    123
    Re: Crazy readings
    No I am in NJ not Houston. And I will post my pool info today
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Crazy readings
    I'm sorry about that. Do post it please as it will help us help you. In any event is there any hope for a water replacement? It is getting late in the season for you I know.
    Essential Links:
