Results 1 to 7 of 7
Thread: Got my work cut out for me...
    My brother's friend stopped by and was amazed by how clear my pool is. He proceeded to practically beg me to help him with his AG.
    Here is what I am up against:
    Eeek! Where to start? I told him to fill it back up and then I will shock it hardcore. Other Suiggestions?
    2003 Marquis Euphoria - 400gal
    Re: Got my work cut out for me...
    JJ
    you're on the right track! Test the fill water so you will know what other adjustments will need to be made, and get some bleach in there pronto... even as you are filling it! There is a ton of goop there... just add the bleach and stir up the water REALLY WELL to mix it in until you can run the pump! (check the water meter to determine about how much water is in the pool so you can add the proper amount of bleach to shock to 10ppm... you don't want to overdo it and bleach out the bottom half of the liner!!)
    This will give you a bit of a head start!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Casey's Avatar
    SW PA
    10,423
    Take lots of
    8)
    Does anyone have a guess how many gallons this pool is?
    sammm's Avatar
    North Richland Hills, TX
    257
    Quote Originally Posted by jjdurrant
    http://www.pool1.com/pool_gallon_calculator.htm
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I guess he never heard the "don't completely drain your pool" advice....
    Good luck, keep us posted!
    After 10 gals of clorox and some vacuuming, algae is gone!!!
