Results 1 to 7 of 7
Thread: CircuPool problem
    Apr 2010
    Sunny Phoenix AZ
    74
    CircuPool problem
    Hi team,
    So it was a few days since I went out and checked the pool....found all sorts of algae spots...went and check the SWG; and it was off completely.
    I toggled the system on/off a few times; unit stayed off. Thinking it may have overheated in the 115 degree weather recently, I let it cool off overnight but this morning, nothing.
    What is interesting is that if you press and hold in the Fuse Reset button on the bottom of the unit, it comes on and seems to be operating normally...until you let go of the button it shuts off immediately.
    Any thoughts on what might be wrong?
    28,000 gallons / Plaster / Hayward 30" Sand Filter / PoolCleaner 4x / PoolSkim / Hayward RS1500 / CircuPool RJ60
    Apr 2010
    Sunny Phoenix AZ
    74
    Re: CircuPool problem
    One add: it is NOT working correctly when I hold down the breaker. It shuts off after about 30 seconds even if I keep holding the button.
    All wiring seems intact.
    22,537
    Sounds like something causing an overload and tripping the breaker.
    If you unplug the cell does it still trip the breaker?
    Apr 2010
    Sunny Phoenix AZ
    74
    There is no difference if the cell is unplugged or plugged in...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Check you end cap connections to the cell. Make sure they're clean and tight.
    My unit had a similar problem (Compupool CPSC48) and my main board was shot. There are several resistors and the top 2 were fried. Nice toasty color. Compupool replaced my unit. From what I understand CircuPool is rebranded Compupool with some modifications??
    Apr 2010
    Sunny Phoenix AZ
    74
    Quote Originally Posted by bobodaclown
    I removed and cleaned the contacts and reinstalled...still nothing.
    Sounds like I'm going to need to call these guys...
    22,537
    I would call them, but it sounds like a board or transformer problem.
