Thread: Suddenly low chlorine usage...good, but why?
    May 2013
    Rockwood, Michigan
    49
    I changed over to pool school methods at start of year and am having my first perfect pool season in years!
    So...it got cold in Michigan 3rd week of July so I started using new solar cover for 1st time in a couple seasons.
    Following recommendations, I target FC=6 for CYA=55. CC all season has been 0.25 since first passing overnight test.
    That has all meant pouring in about 75 ounces of 12% bleach daily...such that it became habitual.
    When I put solar cover on, I kept up that routine for the course of a few days.
    Then I checked chemicals and my chlorine had spiked high!
    I didn't put chlorine in for few days until it got back down, then I did full check.
    CYA=50 FC=4.5 and CC=O.0
    First time all season CC=0!
    Then daily checks, solar cover on every night and probably stays on 3 days per week.
    In the last 10 days, I have used only 1.5 gallons of 12% bleach to maintain proper FC level in pool.
    All other checks are perfect. Pool water is perfect. It all seems too good to be true.
    I certainly don't want to jinx it, but is there a logical explanation for my extremely low chlorine usage?
    Pool: 24,000 gallons, IG, Plaster, Sand Filter, 3/4 HP Pump, Year 2000 Install, Polaris auto vacuum, Lochinvar Heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Suddenly low chlorine usage...good, but why?
    The solar cover will help some with FC loss from the sun and also not swimming as much will consume less FC
    Less FC loss is a good thing. Sometimes with my cover on I only lose 1-1.5 ppm a day. My cover is clear also.
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The cooler weather (and cooler water temps) also tend to help lower FC loss. I have noticed this over the past couple of days here due to the cooler weather and water temps compared to last week when air temps were in the 100's. In my case, this is the only variable that has changed.
    May 2013
    Bay City, Michigan
    283
    exactly what was said above, the solar cover during the day lowers FC loss, the colder water lowers FC loss also. Haven't been in our pool here in Michigan since the heat wave many weeks ago. (no heater) Our pool is 12500 gallons (half the size of yours) and only use 16 oz a day (covered and unused) and still ended up getting higher than I was targeting.
    Now during the MI heat wave, our water was too warm and was leaving the cover off all day/night and because of the warmer water and no cover, had to use 64 oz to 80 oz a day. (16oz = 1ppm for me)
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Overall chlorine reaction rates double every roughly 12F temperature rise. So conversely, they slow down significantly as the water temperature drops. Because I have a mostly opaque solar cover, I can see the chlorine loss rate drop from 0.7 ppm FC per day at 88F (when the pool is not used) down to 0.071 ppm FC per day (1 ppm FC every 2 weeks) at 50F over the winter.
