Thread: New test kit. Are these readings good?
    Aug 2013
    Dallas, TX
    78
    I just did my first test with a TF100 kit, and got the following readings:
    FC = 5.5
    CC = 0.5
    CYA = 50
    CH = 270
    TA = 80
    pH = 7.5
    I've been using bleach as my chlorine. I have an Intex vinyl pool. Are these readings good?
    23,000 gal. IG gunite pool, DE filter, elevated spa with spillover, Polaris 280 cleaner
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New test kit. Are these readings good?
    Nothing too bad there, although I do worry about your CYA number since you said you just did the test and it is almost midnight. Correct lighting it critical to getting good results on the CYA test, this test should be done outdoors under sunlight with the sun to your back and the view tube held at waist level. Trying to perform this test under artificial light will tend to give bad results, often reading low.
    Ike
    Aug 2013
    Dallas, TX
    78
    Sorry, just to clarify, I performed the test at around 6:15 this evening. I was indoors when I did the test.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    So long as there was sufficient light as Ike describes above, you're good to go.
    One more tip, as thus test is very subjective, many of us also like to advise the 1st time cya testers to repeat the test several times. This can be done with the same solution of reagent and pool water without effecting the results. Simply squirt it into the tube after you have followed the instructions for mixing, then resting, then a final mix and when you're ready to test again, just suck it back up into the squeeze bottle, you'll get most of it out of the graduated tube this way, then pour the rest back into the squeeze bottle. Cap it, then turn it end over end a few times, no need to violently shake, then try again, squirting it back into the test tube again.
    Do this as many times as you feel you need to in order to get consistent results and feel confident with the test.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    30,431
    Your test results are close to perfect.....keep them there and enjoy your pool.
