Results 1 to 11 of 11
Thread: Recommendations for auto fill devices?
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    We purchased our home in December and I am finally feeling like I have a handle in pool maintenance thanks to these forums. My only problem is that for the 3rd time this year I have turned the fill on in my pool and then forgotten it and flooded the pool and yard. Of course this only happens when I FINALLY get the chems balanced. Anyway, I don't fill from a hose as my equipment has a fill button that fills the pool at one of skimmers. I know that if I use a hose there are devices that will detect the water level and turn it on and off. I am wondering if there is a similar device for a pool that has a built-in fill feature that my pool could be retrofit with? If so, who makes them and how much can I expect to spend on it?
    Complete pool newbie in Double Oak, Texas (part of D/FW Metroplex)
    40'x24', 32k gallon, DE, In-Ground, Plaster/Pebble, Hayward Pro-Grid DE7220 Filter, 2 - 2.5 hp Hayward pumps (one for filter one for waterfall) addition smaller pump to run robot cleaner, AquaLogic PS-8 SWCG, Spa
    38,537
    Re: Recommendations for auto fill devices?
    Mine has a float valve that regulates the water level. Is your electric that just turns the water on and off? If electric, surprised it does not just have a timer option.
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    No luck with the timer option. Honestly, even if I couldn't get a water level detector, I would be happy if there was an auto shutoff timer that could be set for 20 minutes or so. But it doesn't appear mine will let me set a timer for that.
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    Does anyone know if it is possible to create a timer on my Hayward/Goldline system? The Fill is connected to "valve 3" and all I really need is to be able to set up a timer similar to the Super-Chlorinate so that it will automatically shut itself off after a designated amount of time. Typically I never need to add more than about 20 minutes worth of water but it has been flooded repeatedly because it gets turned on and then we forget to shut it off.
    38,537
    Oh ... if the fill is hooked up to a valve in the Goldline Automation (you do not have that in your signature), then it should be easy to set up a timer. I think you can either set it to come on for a certain amount of time each day or you could have a countdown timer after you push the button to turn it on manually.
    Let me review the manual.
    Which Goldline do you have?
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    I think it is the AquaLogic PS-8 model. (At least that is what I see on one of the stickers inside the panel. I'm attaching photos in case I am wrong.
    I am grateful for ANY help you can give as even though I have my pool chems under control...the automation system still intimidates the **** out of me.
    38,537
    Oh, yeah you are golden. I have the P4 and it looks like you can not do a countdown timer on Valve 3, but in the PS models you can
    Go to the Configuration Menu that is locked.
    Hold the < and > buttons for 5 seconds to unlock the menu.
    Use the > button to scroll through the menu until you get to Valve 3.
    Push the + button to scroll through the settings for Valve 3.
    At the "Function" setting it sounds like it is set to "Manual On/Off" change that to "Countdown Timer"
    I think you also want "Interlock" to be "disabled" ... this will allow the valve to be open even if the pump is off
    And that is all in Config Menu so exit that.
    Then enter the Timers Menu and set the number of minutes you want Valve 3 to stay on after you manually turn it on.
    That is all ... of course watch it the first time to be sure it works as expected.
    Alternatively (although not recommended), instead of "Countdown" you could make it "Timeclock" and have it run for a certain period every day.
    Let me know if it works out.
    EDIT: Although looking at the pictures, yours is a little older model than the ProLogic manual I was looking at ... so I HOPE it is the same for yours.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    I just set a kitchen timer to remind myself to turn off the water. It would be really be nice to have an auto turnoff though.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    Jblizzle you are a POOL GOD! Everything worked perfect for making the change to my configuration! I can't actually test it yet since my pool is already at capacity and my water bill will be outrageous this month from my earlier over site. Once levels go down I will grab a cocktail and enjoy watching the pool fill and turn itself off. . I'll let you know then if I have any issues.
    As far as setting the kitchen timer, I normally set the timer on my phone, but the last time I filled the pool my phone rang in the middle of setting it and my ADD kicked it and I completely spaced it the second I answered the call.
    38,537
    You are going to inflate my ego
    You could set the countdown to 1 minute the first time so you do not have to stand there for 20 minutes or whatever to test it out.
    N2ition's Avatar
    Jan 2013
    Double Oak, Texas
    16
    The timer only works in 5 minute increments...but trust me, 5 minutes is infinitely less stress than leaving the stupid fill on for 5+ hours. A five minute test today would put me at overflow again (it fills FAST) and I just got the chems balanced out again.
