Results 1 to 8 of 8
Thread: BBB?
    BBB?
    I'm just wanting to know if we can use liquid bleach from say walmart to sub for 3" tabs or shock bags?
    Re: BBB?
    I cannot find where and if it says we can do this anywhere please point me in the right direction.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: BBB?
    We generally suggest use of liquid chlorine / plain bleach instead of dry forms of chlorine, see the pool school link in the upper right for lots more info
    38,262
    Re: BBB?
    Welcome to TFP!!!
    It says you can right over there >>>> You can use bleach in your pool instead of tabs.
    Generally bleach is the BEST source of chlorine as it does not have any of the side effects that the solid forms have .... do NOT believe the pool store if they tell you different ... in fact, just stay out of them for anything chemistry related.
    Do you have one of the recommended test kits?
    It could also help if you add your pool details to your signature and your location to your profile: pool-school/read_before_you_post
    Re: BBB?
    I'm sorry i had added that info somewhere and its not showing up.20k gal,ig vinyl,1.5 hp,250lb sand filter.
    38,262
    Re: BBB?
    Then you must not have added it to your signature as decribed in the link I provided. No big deal for now, but could avoid questions in the future.
    Re: BBB?
    Ok,I found it!It's in table of contents.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: BBB?
    I use bleach EVERY day.
    WalMart great Value is very cost effective. the Liquid Chlorinatr over ni the pool section is even less expensive. I try to buy this first
    and if they are out... it buy the GV extra strength.
    -- Guy --
