Results 1 to 15 of 15
Thread: Hayward Eco Star Questions
    Jul 2013
    Puerto Rico
    76
    Hi!
    I'm starting the installation process of a new Eco Star pump connected to the Hayward Aqua Plus unit.
    1) Is it possible, in case I the Aqua Plus fails, to run the Eco Star separately with her own controls?
    2) I'm replacing a 1.5hp Super Pump on 1.5 inch piping and the Eco Star has 2 inch connections. Please share any good or bad experiences & solutions when running a 2 inch, up to 3 hp pump where a 1.5 inch, 1.5 hp pump was.
    I'll document the whole installation process (pics & info) and post on the forum starting Monday.
    Thanks in advance!
    J
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    38,364
    Re: Hayward Eco Star Questions
    1 - Certainly
    2 - Your new pump is WAY bigger than your old one and with only 1.5" lines (how many suction lines) you will not want to run it near maximum RPM. I would suggest using 2" on the pad where ever you are making changes and just use a reduced to 1.5" when needed.
    Post up a picture of the current pad and we can offer ideas. Adding unions around the pump can often help deal with leaks or working on the pump if needed.
    Jul 2013
    Puerto Rico
    76
    Thanks!
    I was wondering that! (Using 2 inch at the pump pad and then 1.5 inch reducers when going back in ground and from ground).
    I asked Hayward about using a 3hp with the DE3620 filter where 1.5hp was and they said ok because of new pump being VSP.
    What is the 1.5hp Super Pump speed?
    Jul 2013
    Puerto Rico
    76
    I have 3 suction lines (main drain, skimmer & spill over spa). I used to run main drain & skimmer only to get good suction and spill overflow
    38,364
    Not sure what you are asking?
    All single speed pumps and 2-speed on high run at 3450rpm ... low speed is 1725rpm
    BUT
    the wet ends are designed differently. At the same RPM, the Ecostar will more WAY more water than the SuperPump due to the design, impeller, and motor size.
    It is "OK" to use the EcoStar because you can limit the max RPM to no be too much for the filter and the plumbing.
    Jul 2013
    Puerto Rico
    76
    Here's the pad.
    The water heater will be replaced with a line heater so I'll have more space.
    38,364
    Is the automation setup? I do not see any actuators for valves to switch to/from pool and spa modes.
    I would suggest using true pool valves (like Neverlube or equivalent) instead of the ball valves.
    You may have to cut the vertical pipes coming out of the floor in order to line up with the height of the EcoStar (not sure if it is different from what you have now). Of course then you can go to 2" pipe
    Jul 2013
    Puerto Rico
    76
    I want to put in all new pipes & valves on the pad. The extra space will be good for the SWG cell, flow meter, etc. so going to 2 inch on the pad is no problem.
    I'm now concerned about the max speed.
    This picture will be the "before" picture.
    At the moment, I plan on just put in modern valves but no automation to them.
    Jul 2013
    Puerto Rico
    76
    Also, filter is getting a complete overhaul!
    All o-rings, ribs and new air relief valve. Multi port valve is 1.5yrs old
    Jul 2013
    Puerto Rico
    76
    What would be a safe max speed?
    38,364
    I have no idea.
    The worst that could possibly happen is crushing your filter grids, BUT, you have a pressure gauge on the filter that will help you prevent that. Stay at a reasonable pressure and you should be fine.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    What about making a 2 manifold for the intake being feed by all the 1 intakes placing upgraded valves on the 1 pipes . And using 2 for the pad plumbing. Make a 2 return manifold run all the returns off that. Placing upgraded valves on the return lines not on the manifolds.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Jul 2013
    Puerto Rico
    76
    Sounds good!
    Jul 2013
    Puerto Rico
    76
    Ok, I did the sizing and the max speed would be at 2000rpm.
    Since the EcoStar comes preset at 3450rpm it is probably better to install the pemp first (no AquaPlus), set max speed and then install the AquaPlus and connect the pump to it.
    Suggestions?
    Jul 2013
    Puerto Rico
    76
    Hi!
    Alright, tried some max speeds and got the pump to 2900rpm which got the filter to 15psi which was the clean pressure with the old pump.
    Much better water flow!
