Results 1 to 8 of 8
Thread: where to go from here?
    hello everyone. I live in Phoenix AZ and Have a salt water pool. I just tested my water with the Taylor FAS-dpd kit and these are my results
    Salt at a 4300 ( machine states 4000-4500)
    PH 7.2
    FREE Chlorine 4.5
    Combined Chlorine .5
    Total ALK 70
    Calcium Hardness 650 ( high I know but water here in AZ is very hard)
    Cyanuric Acid 90
    phosphates 0
    I ordered my own testing kit due to pool stores giving very drastic different results. Now I'm lost. I was wondering if any of you knew of a accurate program that I could enter these numbers into and it tell me what to add to pool. any and all help would be appreciated. Thx again - Rob
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: where to go from here?
    Welcome! How about the pool calculator here in pool school. We knew you were coming!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Hi, welcome to TFP! You can plug your numbers into the Pool calculator to see if anything needs adjusting. It is very simple to use, just enter your current results in the "now" column and the desired numbers in the target column. In the yellow box at the bottom of the pool calculator you set up they type of pool and method of chlorination. Size of the pool goes at the top. There are suggested levels for each test value block.
    Love TFP? Become a
    TFP Supporter!
    38,528
    Welcome to TFP!!!
    I would suggest you spend a little time reading in Pool School so you have some understanding of the chemistry and will know WHAT needs to be adjusted.
    If you just plug numbers into the calculator with no understanding, you may end up changing things that are not needed.
    Looking at your results ... besides the high CH, the only thing out of range (see Pool School) is your CYA is a bit on the high side. But as long as the pool is clear and you keep the FC in range (personally I would keep it above 5ppm) you should be fine.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you use pool calculator don't forget to set the suggested goals for trouble free pool, SWG and what ever type of bottom your pool has.
    Ike
    30,432
    A giant shout of agreement with jblizzle's post. Calculators can do math.....nothing else.....they cannot think or understand how to manage your pool.
    Read "The ABC's of Pool Water Chemistry" up in Pool School for starters.
    Thankyou for the helpful info guys. I will in roll in school
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    robclark:
    The previous posts have you covered. But I will extend a warm welcome to TFP!
