Thread: Normal amount of bleach daily?
    Split by moderator from HERE since it turned into a thread hijack. jblizzle
    I am presently adding 6 quarts a day to keep my fc where it needs to be. Its not cheap bu it sure is easy!
    23K, vinyl, above ground, 2hp-2 speed, sand filter
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Adding bleach daily?
    Quote Originally Posted by tonishu
    6qts seems a little high. Have you run an OCLT lately?
    Mar 2007
    San Rafael, CA USA
    12,082
    Yeah, 6 quarts of 6% bleach in 23,000 gallons is 4 ppm FC so per day that's on the high side. You should post a full set of test results. Your CYA level might be too low.
    yes it is high, I live in the the deep south, lots of rain here lately, we had over 5 inches on Wenesday, it is really doing a job on the cya. When I tested it yesterday it was less than 30. Last month I had it at around 50-60. I need to bring the cya up, but don't want to waste it, we are expecting a lot more rain this weekend. Any ideas? What level do you guys recommend that I get it up to and maintain?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If your CYA has dipped from 50-60 down to near 30, you will see a much higher consumption of LC (liquid chlorine). When i was at less than 30CYA, I was using 40-60 oz per day, now I am in the 40-50 CYA range and LC is down to about 20 oz/day.
    -- Guy --
    That is what I figured, I will be making a stop at the home depot this evening for some and will be working on getting it back up. Just wish the rain would stop!
