Thread: Calcium and Chlorine troubles
    So we had an issue with our Rainbow 300 chlorintaor not doing its job. It was old and needed to be replaced, the BB in the elbow was pasted in and not allowing the proper amount of water through. So after that all went well for a few days the FC we kept steady around 2-3ppm then it took a nose dive to barley 1. We cant seem to bring it up and now we have mustard algae we are treating for. I shocked the pool and we vacuumed up the algae on waste and added some Banish.
    Now my CH is reading 0 and 2 days prior it was at 280. I am using a Taylor test kit and when i go to add the purple 11 to make it turn red it looks like it is reacting with something because it instantly fizzles and after 5 drops its still clear. I have replaced the chemicals in the bottles and done all i can. I have a feeling it might have something to do with the Banish but it doesnt say anything about affecting CH.
    Any Thoughts?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Calcium and Chlorine troubles
    Wow... all over in this note.
    Can you post a full set of results?
    See this posting Read This BEFORE You Post first and then PoolSchool.
    We need these so we can know where to start.
    -- Guy --
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You are adding copper to the pool, it can cause stains, turn swimmers hair green and cause problems. You say you have shocked the pool for the algae, but did you follow the SLAM process that we recommend? Do you have a good test kit? Post a full set of test results and we will see if we can advise you.
    chiefwej
