Results 1 to 9 of 9
Thread: Closing Above ground Pool with Solar Panels
    I've tried to find a post on the steps to close an above ground pool. Any links?
    I plan on not using a cover since I've been told they are not really necessary and in fact around here have actually caused many pools to collapse.
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Closing Above ground Pool with Solar Panels
    Can you fill in your detail in you signature
    Quote Originally Posted by FROM: Read This BEFORE You Post
    Profile
    Please put the city and state in which you live in your profile. Your climate is important to the advice you receive.
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the size, model number or flow rate of the filter.
    If you know, please tell us the size pump in HP. Also mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Please keep your signature to 5 lines or shorter. Everything above can be stated quit compactly. For example:
    19K gal, IG vinyl, 1/2 HP WhisperFlo pump, 200 sqft cartridge filter, AutoPilot Digital SWG, Dolphin Dynamic cleaning robot
    Information in your signature will show up each time you post. This helps the people answering your questions by providing the basic information that affects nearly all of our recommendations.
    To change your profile and/or signature, click the User Control Panel button, just below the TFP logo at the top left of every forum page. Then click the Profile link, just to the right of Options in the sub-sub-heading. On that page you can enter your location. Finally, click on Edit Signature link, towards the left under Overview & Profile, to change your signature.
    -- Guy --
    OK I think i covered everything
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    OK... now we need to wait for a cold weather resident.
    I live in sunny California and the last ice I saw in my pool was from my cocktail.
    -- Guy --
    Jul 2013
    Columbus, Ohio
    114
    Quote Originally Posted by outdoor
    Pool School has an article on closing an above ground pool. I don't know how to link to it for you. I have an in-ground so I cover mine.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    Hmmm a bit vague on some items. What do i do with Skimmer? drain, remove hose plug??? then what just leave plugged and what about snow water build up will it not freeze and potentially crack skimmer?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    IIRC the "gizmo" mentioned is a plastic "bottle" that prevents the water from breaking the skimmer body. Google Gizmo and you will see them.
    -- Guy --
    I thought someone said you can also use pieces of noodle in the skimmer, basically something that takes up space and can contract.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Here is another way to protect the skimmerhttp://www.poolproducts.com/SPP/ ... 555&FNM=97
    Jeff
