Thread: Going away for a week-recommendations on how to leave my AGP
    Jul 2011
    Lehigh Valley, PA
    163
    Hi guys:
    I am going on my first vacation in 3 years with my family (OBX baby !) and I had a couple questions on how to leave my AGP.
    I have the filter set to go on low speed about 8 hours a day. I was thinking of doing the following. Bring the pool up to shock level (about 15), put the pool solar cover on, let the pool pump run on the same schedule. Anything else I need to be careful on ? Is it ok to leave the solar cover on everyday--it does keep a lot of leaves out of the pool.
    Thank u in advance
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Going away for a week-recommendations on how to leave my
    You're done SLAMing when:
