Thread: Best heat pump run time?
    I was searching for any threads on best times to run a heat pump to maintain temperature... I did not find any.
    I don't want to run the pump 24 hours. I know that the most efficient heating time is when the outside temp is highest... so, my real question comes down to whether it is cheaper to keep the heater off at night and just let it run again after about 10am when the outside air temp is creeping back up... or should I allow it to come on a couple times at night for an hour or so to keep temp from dropping too far... curious is anyone has done any analysis on what works out to be best for run time and cost. If you have a heat pump, when do you run it and for how long, to maintain pool temp for afternoon and evening swimming?
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Re: Best heat pump run time?
    Running only during the warmest part of the day is most efficient. The only disadvantage is that the water will be a little cold in the morning. Other than that, afternoon heating is definitely the most efficient.
    Ft Lauderdale, Florida
    1,455
    If you don't have a solar cover on your pool overnight, you will lose a lot of heat. The best thing you can do is to start using one, if you are not currently using a cover. However, during the day operation is best.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Thanks, Sean. I am looking for a good solar cover. Just got the SQ175 hooked up last weekend. Seems to be working very well. I will have a week or so of run time where it is off at night and on in the morning until it gets back to temp... It will be interesting to compare and see how much less run time I will need once I have a cover.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Take a look at this place for a cover http://www.solarcovers.com/page/index?g ... 4AodK0wAzA
    Jeff
