Thread: Rust Spots on Main Drain
    I have a few ... 3 or 4 rust spots on the edge of my main drain. Not on plaster. Does anyone no anyway to remove the few spots?
    Thanks
    16x30, 15,000 gal Plaster IGP , Hayward North Star Pump 1/2 HP, Hayward Cartridge Filter Model C4025, UltraPure Pool Oxidizer, Polaris 280, and Aqua Logic AQL-P-4 controller. Pool built 6/2/05.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Rust Spots on Main Drain
    Since I would first suspect metal staining and since they are on the main drain at the bottom of the pool, try dropping a few vitamin C tablets (which contain ascorbic acid) on the stain and see if it lightens after a few hours. That would indicate metal staining. Turn pump off when doing this since you do not want the tablets to move off of the main drain.
