Results 1 to 10 of 10
Thread: Costco bleach 8.25
    Jun 2013
    Northern NJ
    123
    Costco bleach 8.25
    So I'm new to this Bought some Clorox at Costco. When I returned home, I noticed it was 8.25% not 6% as in the forum. How can I use this ?
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Costco bleach 8.25
    Poolcalculator.com bleach percentage can be changed by the user.
    Jun 2013
    Northern NJ
    123
    Ok thanks
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Page needs to be updated with 121oz selection. For now putting in a little extra.
    The jugs do say they are equivalent to 182 oz of 6%, so if you Use those numbers and go by Jug count alone it should be equivalent.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Jun 2013
    Central Texas
    9
    Or try this version. calc.html
    It has the 8.25% and 121 oz.
    15.5K gal, IG vinyl, Hayward 1/2 HP, AquaView 3.14 sq ft sand filter (above ground pool installed in ground, so no main drain), TF-100 test kit w/SpeedStir, BBB, Liquidator.
    Aug 2013
    Oklahoma City, OK
    134
    Quote Originally Posted by dspille
    I didnt know about this other calc. Thank you!
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Thanks, I didn't know about it either, the only thing I see right now is the amounts are not sorted, but tacked on the end.
    K-2006 Test kit
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Is a moot point now but I had been calculating with 6%, then with 10% and averaging the two results. Basicly gave a result for 8% but I figured that was 'close enough for guvmint werk'.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    On the pool calculator, the result given in ounces is still correct for the % of bleach entered. It just can't convert the results to the new jug sizes.
    Love TFP? Become a
    TFP Supporter!
