Results 1 to 10 of 10
Thread: Still losing FC Overnight
    Jun 2008
    Knoxville, TN
    83
    Got my FAS/DPD test kit on Wednesday so I've been recording the numbers since then. Friday night I changed how I was handling the chlorine -- before I was getting it to shock level each time it would drift down. Now I'm trying to keep it above shock level so when it drifts down it never gets below shock level. With my CYA of 60, it says shock level is 18. I've kept it above that for 36 hours now. From last night to this morning my FC dropped from 22.5 to 18.5. The CC still reads something around 0.5.
    I've brushed and vacuumed the pool the past 2 days. I did find a couple of leaves at the bottom but for the most part the walls and floor are clean. Started all this Thursday a week ago. Turned the pool from green to blue overnight but the water has stayed cloudy since. I've added a mountain of chlorine but have kept it at the highest the past 2 days.
    It sure gets hard to keep doing this. Is it possible I've backwashed too much ? That the sand filter isn't doing it's job to clear the water ? I changed out the sand but while the water was still green. The water seems to circulate well. I did a lot of skimming by hand the first few days but there's hardly anything floating now -- a bug here and there but that's it. I keep both baskets empty.
    Just hoping I'm on the right path to get this water to clear.
    Steve
    24' Round A/G Pool, 13500 Gallons
    Sand Filter
    TA 70
    Ph 7.2 (last tested before these high shock levels)
    CYA 60
    FC 18.5 CC 0.5
    24' Round Above-Ground Pool, 13500 Gallons
    Triton Meteor Sand Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Still losing FC Overnight
    You are on the right track. I can't advise you about the sand filters because I don't know anything about them really, only what I have read on this forum.
    It can take several days for your shocking to work, try again tonight. Keep your level up during the day today, check after dark, add bleach, check again in the morning.
    POP!!!
    Guest
    You are fogetting the most important part of clearing your pool--PATIENCE!!!!!!!
    Once your FC is holding, there is NO CC and there is NO green then you have killed the algae. At that point you have to wait for the filter to clear the pool. If you want to speed it up your only real option is to "floc, drop, and vacuum to waste" which means add a floculant, let the pool sit overnight so everything drops to the bottom, and then VERY CAREFULLY vacuum the dead algae to waste. This will clear you pool more quickly BUT it's a lot more work and unless you really need the pool quickly is often not worth the trouble.
    As far as how much to backwash, keep an eye on your pressure gauge and when you get about an 8-10 psi increase then backwash.
    Jun 2008
    Knoxville, TN
    83
    Thanks guys. I really am trying to be patient. But this is like day 10. Whew.
    One other factoid......we just bought this house and inherited the green swamp pool. My guess is it has sat this way for 2 years now.
    Steve
    Guest
    Quote Originally Posted by ssmith1627
    consider it day 2 since you were not really doing it right before.
    Jun 2008
    Knoxville, TN
    83
    Understood.
    11,969
    Quote Originally Posted by waterbear
    Exactly....
    Jun 2008
    Knoxville, TN
    83
    It never drifted anywhere low. Just below shock level. I've had it above 13 since Wednesday night.
    Steve
    You should brush the entire pool once a day while at shock level. Be particularly through in areas that might have bad circulation, around steps/ladders etc. Brushing helps expose the algae to the high chlorine levels and can help speed the process up.
    Jun 2008
    Knoxville, TN
    83
    I'm brushing and vacuuming every day now to try to cover all the surfaces -- steps, walls, floor -- as well as to churn things up for the filter.
    Inch by inch.
    Steve
