Thread: Whirlpools and suction noise at outtake
    10k gal, AG, 1 1/2 hp .18 spl Hi-Flo Waterway 2 speed pump, 100 sq ft Clearwater cartridge filter, installation 6/2010 doughboy 24x16 oblong
    On our outtake, we constantly have whirlpools forming and loud suction sounds coming from the whirlpools, any idea why?
    16x24 oval doughboy above ground
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Whirlpools and suction noise at outtake
    Welcome to tfp, Lfogarty
    I assume this only happens on high speed?
    That happens to me when I have my return flow pointed too high. Try some different angles of return flow. Also, if you water level is low, it may be more likely to happen.
    22,548
    Just agreeing with Linen. I get them sometimes depending on how I aim the eyeball. Try aiming a different direction and you should be able to stop them.
    Also, if you have small eyeball(s) you can increase the size and it will slow down the velocity and up the volume of flow and that may help.
    Thanks will try repositioning. Why would the water level cause this?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Essentially the high flow rate is causing a vacuum due to it's swirling action (the high velocity water is piling into quieter water and deflecting into a circular pattern with the vacuum created in the center), the deeper it is in the water the less likely lower pressure area will form a vent all the way to the surface.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I have never heard of the returns being called outtake. I assumed you were talking about where the water leaves the pool (skimmer) and gets sucked into the pump, not where the water "returns" (eyeballs in the wall with water flowing into the pool) to the pool. If you are getting a vortex in the skimmer, it could also make noise.
    Return Eyeball
    Skimmer
    -- Guy --
