Results 1 to 12 of 12
Thread: Question about timing of tests and adding stuff
    Jul 2012
    Cedarhurst, NY
    16
    My pool is 33900 gallons. I have been using BBB method for over a year, but testing today my CYA = 0 and FC =0. (Lots of sunshine and high temps this summer, plus I haven't been as obsessive about monitoring).
    Not a problem , I added bleach to bring CH = 12. Let that swirl around.
    How long before I can test reliably for CYA?
    Thanks!
    Craig Ramseur
    27600 gallon IG pool
    Hayward S244T sand filter
    Hayward Super II 3/4 HP pump
    Taylor TF100 Test Kit
    38,284
    Re: Question about timing of tests and adding stuff
    You lost me. You tested CYA at 0 and then added bleach for a target of 12ppm??? That is awefully high. If you did not add any CYA, then it will be 0 whenever you test it again.
    Also, all the CYA does not simply dissappear. When was the last time you tested for it and had a reading?
    Jul 2012
    Cedarhurst, NY
    16
    2 weeks ago CYA was 40.
    I thought that the lack of chlorine would skew the CYA readings. Its that mistaken?
    Craig Ramseur
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Add CYA to raise your level to 30. See the chlorine cya chart in pool school to see what your MINIMUM FC is for that level. CYA might not show up for a week on a test. From 40 to 0 in two weeks sounds like a testing error unless you changed out MAJOR water.
    Jul 2012
    Cedarhurst, NY
    16
    I was leery about adding CYA, only because I thought that it should not leave the pool.
    There has not been a major change of pool water. Some rain, some refill after backwashing.
    That's why I was concerned about whether the CH level affects CYA readings.
    Craig Ramseur
    38,284
    CH = calcium hardness
    FC = free chlorine
    Do you have any CC (combined chlorine)? And what are you using to test? {please do not say test strips }
    The chlorine level does not affect the CYA test result.
    Jul 2012
    Cedarhurst, NY
    16
    Ok I made a mistake in my abbreviations. I am talking about chlorine. and CYA.
    I use the daily test kit first, then the TF big test kit.
    I added the powder and the color did not change at all.
    I did not test for combined chlorine.
    I realized that the CYA should not have leached from the pool, so I added enough chlorine to raise the FC to 12.
    I just want to know when I should test the CYA level again, after adding chlorine.
    Does the chlorine level affect the CYA test at all?
    I have liquid conditioner here already...in the closet.
    Thanks
    Craig Ramseur
    38,284
    Check the CC ... really should do that every time you test.
    The CYA should not have disappeared. On the rare occasions that it happens (usually over winter or in a swamp), it is sometimes converted to ammonia which results in high CC readings.
    Apr 2010
    East Texas
    9,600
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Something isn't adding up here. Please re-test CYA. It should NOT have all disappeared based on the water change you mention. As for testing after adding Chlorine, get enough sample to test everything when you pull a pool sample. If you are concerned about getting a high Chlorine slug in your sample after adding bleach...or whatever, this will prevent any issues. Or run all your tests, then add accordingly.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by cram
    In the friendliest tone: Sorry but yes it is. Lack of Chlorine does not affect CYA either. Not the level in the pool, and not the test in any way.
    Essential Links:
    Jul 2012
    Cedarhurst, NY
    16
    Okay...Thanks I'll get on with it then.
    Craig Ramseur
