Thread: Leaky Shaft Seal - Hayward Super Pump
    May 2013
    Erie, PA
    53
    Hi All,
    I'm having an issue with a leaky shaft seal. I've replaced the seal 3 times already. First time lasted a few weeks, second and third time less than a day before it started a slow drip again.
    Any thoughts on what else could be wrong? Possibly the seal plate? I couldn't see anything visibly wrong with it when I checked it. Maybe I'm missing something.
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Leaky Shaft Seal - Hayward Super Pump
    Check the o-ring. Someone else had the same problem a couple months ago. Brand new seal, still didn't go away. Turned out an o-ring wasn't seated properly.
    May 2013
    Erie, PA
    53
    Hi Smykowski,
    I'm not sure which o-ring you're referring to. The housing gasket?
    The last time I had it apart I could definitely see it was leaking behind the shaft seal.
    Smykowski's Avatar
    Sep 2011
    3,065
    I think in his case, it was the o-ring between the pump housing and the pump cover (depending on the pump it might be called the diffuser). If it's a slow enough leak, the water will work it's way down to the bottom, dripping like it's a shaft seal. However, if you can see the water up high and know it's coming from the seal, that might not be your problem - just a suggestion from someone else's solution.
    What kind of pump is it?
    May 2013
    Erie, PA
    53
    Hayward Super Pump.
    Yeah, when I took it apart I could see the water line where it was dripping behind the seal plate.
