Thread: How do I add a second suction point?
    Feb 2013
    Melbourne, Australia
    102
    Not sure if this is the correct place for this but here we go.
    I am about to undertake a refurb of our pool and before I resurface, I would like to add both a light and a second suction point for an automatic cleaner at least. It currently has the skimmer, a floor suction point via the skimmer, and two return jets. That's it. I will be moving the pump/filter to the back of the summerhouse (when it's built) when I fit the heating and SWG so a re-plumb will be on the cards. I will expose the exisiting points at the back of the concrete, then cut off and join the new pipe.
    I assume I can drill/jackhammer a new point in and then epoxy/grout the pipe in position, make watertight then resurface?
    I am also going to add a light or two(there are none at the moment), the LED surface mount ones look good but the cabling is an issue. I figure I can chip out a channel for a conduit and do the same with epoxy/grout, but how does it need to go? I'm assuming it just goes above the waterline, so just under the paving, but there will not be a niche so will future light changes be difficult?
    Does anyone have any recommendations as to anything else to add in? I'll leave a plugged branch off both the input and output lines incase I want to add a waterfall or whatever. Any other suggestions?
    I'll post pics as I go, should be a dramatic transformation from 80's to modern if all goes to plan. I am a carpenter by trade, formwork specialist and general do-it-yourself handyman on most fronts so I'll do what I am capable of doing by myself, and employ trades as required.
    Thanks for reading!
    41k litre (11k gal) shotcrete in ground pool, Hayward super 2, Davey Monarch 28, zodiac SWCG
    - undergoing a transformation!
    2nd season Pool Owner. TF-100 testing
    Melbourne, Australia.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: How do I add a second suction point?
    If you are going to dig, yes, there shouldn't be too much trouble adding in another suction port to your pool. A 2-1/2" (65 mm) coring drill would probably work, then secure the new port to the pool with hydraulic cement.
    I don't see a problem with using a surface mount LED light to the pool, with running the wires in conduit buried in a notch to the top of the pool wall. Depending on how the light is constructed, you may be able to put a waterproof connector just out of the conduit either in the light or in a junction box above grade away from the pool. Personally, I'd go with a low voltage style light, just to keep mains voltage that much further from the pool.
    All in all, it looks like you have a good handle on what you will need to do.
    Looking forward to the pics of your progress!
