Thread: Noisy pump
    Brisbane , Australia
    54
    Noisy pump
    Hi
    I have a Poolrite SQ 600 pump that has all of a sudden making a louder noise than normal. I cleaned the whole system and it is working normally suction wise but it is still noisy. After reading some topics here it sounds like it could be the bearing.
    Is this a job I would be able to do myself? Don't really want to take to the Pool Shop as they could tell me anything.
    Thanks
    19,000 gallons
    Zodiac Tri Series SWG
    Hayward S310T Sand Filter
    Poolrite SQI 600 pump.
    IG Concrete, quartzon surface
    Built 1997
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Noisy pump
    As long as you're comfortable taking stuff apart and putting it back together, yes, bearings are a DIY job. If you google "pump bearing replacement" you should be able to find plenty of You Tube videos. Even if you don't find one for your specific pump, anything similar should do it.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    Re: Noisy pump
    Take Smykowski's advice and spend some time learning how to replace bearings. You'll save $$ in the long run. Not to mention the other things that can leak or go wrong with a pump. Its a shame to spend hundreds having a pump repaired for parts that cost less than $10.
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    54
    Re: Noisy pump
    Thanks for the replies. I'll have a go at doing it myself
    Cheers
    19,000 gallons
    Built 1997
